Engine tuning
simplythebest
1,500 RPM
Engine died many times, uncountable times precisely. Must be the fuckerama idling problem, need to tune.
Another question is, i'm using K&N filter for 1.6/1.8 (but mine is 1.3), will there be any problem? Right after I fix this Air filter, the problem occur.
Before this, my idling isn't that bad, but still fugged up I know. I couldn't start the car easily, have to step on the oil pedal when I turn on the ignition.
Any good workshop to do tuning?
wat car r u using n isit running on carbie?u can juz adjust yrself the carbie.....b4 tat u try use STP carb cleaner at rm14.90......spray it at the carbie mouth n rev it while spraying......let it open throttle (open up the butterfly) n oso spray into each small inlet at the carbie mouth......hope tat helps u.....n another thing is consider whether yr auto choke is kong anot......autochoke function is to make yr rpm higher when initial ignition start especially in the morning or when engine is cold.....gd luck
Mine is EFI, need to do tuning.
The thing that I want to confirm now is, can a 1.3 uses 1.6/1.8 filter? Anyone here tried before?
Many people said that it is compatible, they are the same.
But when I check speedworks site, it is not.
Hmm ..
i think there isnt any diff...IMO..coz wats the displacement has to do with the intake?maybe the diff is the diameter of the part where the filter is connected to the intake manifold.
this is for open pod la...but which one are u using anyway?drop in or open pod?
yup.go to some1 who can reset ur timing.coz i think its been tampered.
there must sum difference or not it wudnt be stated 1.6- 1.8... it wud have been stated 1.3-1.8 rite...
btw im using KNN 1.6-1.8 open pod on my 1.5dohc... problem
yeah my waja having exactly same problem. the worst is when my engine ignited not longer enough, when i speeding and sudden press the brake, it would caused engine died also -.- so dangerous when i pressing brake at corner. i serviced at the regular workshop and they did help me cleaned the carbie that you mention and the problem is solved but only for few days and that problem back again now. is it better to tune the car at any regular workshop or proton workshop better? never tuned my car before.
how much they charge u for cleaning it?yr waja is how old?if u send to proton workshop, they'll reset yr ecu to its original optimal performance.....but somehow outside shops can tune it for higher performance which will cost u much la....dun send to proton.....send to eon if u want back original settings.....
thanks bro for replying, my waja almost 3 years i think , jgj . i did that during servicing n changing black oil, cost less than 150 if not wrong. i think they only chage me 10~20 bucks for cleaning it
ooh ic......juz normal cleaning la using some sort of spray stuff.....for the effective cleaning is use the cleaner which cost rm 160......they pour into a bottle n hang it.....n then they pasang the pressured air into the bottle n then spray into yr intake....
so yr waja now still got engine dying?
I have a problem regarding my FJ40 Landcruiser engine, its a 6 cylinder 12V OHV gasoline engine
The oil leaks in my exhaust system and beside the engine block that's why everytime I use it I smell funny inside the vehicle.
Can anybody please tell me the cause why does the oil leaks in my exhaust system and beside the engine block..
Thanks :regular_smile:
normally the oil leaks thru the combustion is due to the worn valve seal and the leaks beside the engine is due to engine gasket. "to kill 2 birds using 1 stone", just do top overhaul. make sure you use original valve seal.
you done!
i'm driving a waja 1.6 auto...i wan to set the rpm higher,wat should i do??if i go to proton and set will they charge me??if yes how much?
you mean the engine idle?? normal efi engine has a idle screw at the throttle body.just adjust it as you want. if cannot, then need to plug the console..i think the charge is vary.other shop also have. proton??sure expensive.
Hi,
Currently driving a carbie. :cry_smile: Engine died when i release the accelerator pedal. When i restart it again, i need to constantly press the accelerator. When i come to a corner, my engine die liao, vy dangerous when car behind following me. Ist oil intake prob ?? My rpm goes up and down. Anyone can help??
Is there any tuning service for an Auto EFI engine? I am driving a Toyota SEG 1.6 auto..
I heard that people are tuning their car to achieve better engine idle, fuel consumption and engine efficiency.
I have done those engine flush, throttle body flush and stuffs.. but never tune...
Please advice.
Regards,
HKNP
Is your car Wira 1.3i? If yes, then the best way to get rid of this problem is adjust the timing. If not mistaken cost rm30 per adjustment. Then after few weeks adjust again and this process will be continue until cannot be adjust anymore. This I will call it a stupid way.
Actually Proton injection engines is no need to adjust the timing for normal condition. Now the question is why the car engine will die when idle? Is because the setting run away? Or is it normal for Malaysian make cars? The actual fact is valve before entering to combustion chamber is blocked. For stock air filter it will take around half a year to blocked that will cause engine to die when idling. If using other air filter, mushroom head type, it takes only 1 or 2 weeks to get blocked. So to clean the valve, how much does it cost? Rm1-2 only.
then how to clean the valve at the cost of rm1-2 ?
Buy a clean cloth open up the valve then clean it. I have posted once over here the photo. Don't know which thread already..
Yes, is the air intake. The exact location is after the air filter and before it connect to combustion chamber, is that called butterfly? If yes, then thanks for remind me. My father in law only show me how to clean it, but never tell me what is it called.
I think this only applies to Wira, others I not that sure.
