Engine Sudden Lost of Power?
AD_EG
6,000 RPM
Hi fellow bro's.
A couple of ppl i know,including my self have experience this issue...out of no where,suddenly you feel there is a noticeable lost of power,some others have other symptoms such as car jerks at certain RPM's....some ppl experienced when vtec kicks(example : 5k rpm),it feels as if there is a rev cut or like engine misfiring for 2-3 seconds then the engine continues to pull through 6,7,8k rpm like normal...but just with less power or not like before....all of this scenario's happened without having any recent mods to the engine,or upgrades or changes...it just happened suddenly.
I am just sharing what we went thought this traumatizing event....after many painful troubleshooting...and the thought that your car will never be the way it was...posting this in hopes that you guys don't face this painful process like we did.
Things we checked/changed :
1.Oil pressure
2.Vtec Solenoid
3.Valve Train
4.Fuel pump
5.Spark plugs
6.Cams
7.Spark Plug Cables
8.Map Sensor
All of the above did not resolve the issue.
Cant really remember what other checking was done...but all of us found the same resolution....it was the ECU....if you have a re-chipped ECU..changing the chip might not be enough...when you change only the chip...the cars performance is improved but it doesn't perform the way its use to...but when we changed a different ECU and re-chip that ECU..then the performance is returned to its prime time...
so ...just remember...when you guys face this issue...if possible just borrow a friends/mechs ECU...and test that 1st....to save you from all the hassle above...
Have a nice Day.:driver:
Or as I has posted and advised.... SEND YOUR ECU for caps replacements...
After caps change some experince smoother and stronger pull......
Some chips spolit because the pin broken or half broken after many in and out of socket
without using the proper method of tool...
Some case, it was inserted reversed direction, then later correct it but chip already half life...
Some case sticker covering the glass on the was removed or koyak thus exposed to uv causing
data inside partially erased....
AD EG,
If you any lubang of rosak ecu pls throw to me..... kay.. TQ:biggrin:
bro,
glad u've solved ur issue like how i did to mine. so rupa2nya its ecu for u also huh? mine was the chip anyways... so quite related.
but u've missed out a couple of what i chanaged as well.
TSP Sensor
Fuel Relay
Fuel Filter
Distributor
and yes, just to recap, either u can opt as what bro E-Tech is trying to shout about, or what me and bro AD_EG went thru, the "rechip" chip.
so try swapping the ecu first.
AD EG,
Sure bro will update you soon....Where is your location in Johor?
bro,
TSP Sensor
Fuel Relay
Fuel Filter
Distributor
Yeah bro...looks like mine was the same case as you...Wat was real funny,when you posted your problem...i advised you to check ECU 1st...now....when i have a problem....i do that last ..and its the easiest...:banghead::banghead::banghead::banghead::banghead:
lolx....anyways yeah my problem is solved... :biggrin:
bro arrow,thanks for sharing what you went through ...and sharing your issue with me over the phone...after i spoke to you...i was 99% confident it was definitely my ECU...
no problem bro, after all, we both were trying to solve some funny issue... we overlooked out ecu's capabilities... hahahaha.
Bro, just want to ask, all the above only happen to re-chip ecu or will happen to any standard ecu?
Based on repair history...std or chipped also will happen.
If during chipping time they change the caps for you then... basically only std will happen.:biggrin:
If that so, how to make sure that my ecu is ok or not beside waithing for the problem occour first?
haaa i got 1 ecu from my fren...
bro e-tech pls pm me ur hp......
wanna send it to u maaaa.......
Bro... foc for me? Thanks...:biggrin:
If got the medical history better still...
e.g now what is the trouble... CEL codes...have anyone tried to repair it....
If can repair,,, will try to do it...
If cannot...korbankan dan ambill spare part only... Thanks...
Anyone else have honda ecu which already "dead" and want to donate for
my "donate your ecu" program?...:wavey:
Bro E-Tech, got such program meh? you should start new thread for that program....my be many people will donate to you....:hmmmm:
"Donate your ECU to saving another HONDA B series car's life"
I start the program for ZTH honda members lor...
Cause nowadays... ecu like P30 getting less and less and harga pun going up
and up.... if do not have this program susah mah....
So components inside the ecu very difficult to get... and if have also very expensive,
e.g the transistors to control the injectors....
So only way is to have this program..... "Donate your ECU to saving another HONDA B series car's life"... :biggrin:
TQ
Good,Good...i want to be a member of that program also...by the way...normally for my car ej9 what type of ecu it using?
TQ
heheh..we donate to you....next time we need any help got benefit or not? :biggrin: help us fix ecu problem for free :rofl:
eh bro...which part of johor are you in?
