engine shaking
sta
hi,
my wira just change engine gsr 4g93 turbo.
the engine is vibrating & shaking badly at idle. idling 900rpm steady. above idling no vibrate.
mounting looks good.
also the spark plug should i use heat range 6 or 7 ?
if normal driving then use heat range 6, if owes revv then use 7.
clean TB n see ..may helps to reduce the vibration...otherwise hv to adjust the idling rpm
as i know , throttle body dirty might cause rpm to dance up and down
but my rpm is steady, just the whole engine vibrating badly
on the road, the power is normal for a stock gsr
