Engine Oil Cooler
wilm3
I noticed my car engine oil dropped to less than half of the dipstick after running 6000km before i service. is this normal? i so frequent high rev to 7-8k rpm and running on 10w/40 semi.
will installing engine oil cooler helps? sifu sifu pls advise...:driver: and normally how much the cost? tks :)
engine oil leak...
1) wash your engine bay...then detect for any engine oil leakage...
2) high rev - white blue smoke came out...possibilities of worn piston ring
3) idling - white smoke came out, high rev, white smoke gone...possibilities of worn out shims...perhaps top overhaul would help solve it...
Good luck on the findings
