Emanage ultimate
Emanage ultimate
VtecGary
Trust Greddy E-manage Ultimate Emanage E Manage Ecu + Kit
TRUST GREDDY E-MANAGE ULTIMATE EMANAGE E MANAGE ECU + 1.2m Wiring Harnesses
GREDDY E-MANAGE ULTIMATE Advanced Engine Control Unit Manager (Piggy-Back ECU).
Software is included in the box as well.
Based on the very popular e-manage is the all NEW e-manage ULTIMATE. New improved functions allow you to tune & manage your vehicle more precisely than before!! The e-manage ULTIMATE is the industries first engine management system capable of communicating via USB cable!! The Data Logger Function included in the software allows users to record their setting data via a PC. Now you can master Ignition & Fuel control at ease.
FUNCTIONS;
Airflow Correction :
Airflow Adjustment Map / Airflow Output Map / Boost Limiter Cut Map / Anti-Engine Stall Map.
Injector Correction : Injector Adjustment Map x2 / Acceleration Injection Adjustment Map / Individual Cylinder Injection Adjustment / A/F Target Value Map / Vehicle Speed Correction Map, Coolant Temp Correction Map, Intake Air Temp Correction Map / Rev Limiter Cut
Ignition Adjustment : Ignition Correction Map x2 / Acceleration Ignition Map / Individual Cylinder Ignition ADJ Maps / Ignition Cut Feature / A/T Shift Compensation Feature
Others : External Output Map (VTEC) / NVCS Control Map / Analog Output Map / Idle Stabilization Map
Serial Port : External Data (such as GReddy Warning Meters & other future optional products) can be monitored and recorded in real time through a data link cable.
Switch Port : Data Logging & Ignition Cut features can be activated with the use of an optional Remote Switching System & Switching Harness
Option 1/2 : GReddy Pressure Sensor, GReddy Temp Sensor, A/F Input Harness, Multi Switching System Adaptor, External Switch & Factory Pressure Sensor.
MORE INFO ON WEBSITE: Total Tune Up GReddy By TRUST
Whole kit is brand new and never used comes with all manual and software!
Im looking around RM2300 for the whole lot!
So grab your self a bargain!
cheerz,
