Emanage Ultimate - Guidance
AD_EG
6,000 RPM
Hi bro's.
just need some advice or help using the emu.
1) The emu is already tuned by a tuner. i wanted to run a datalog, so I connected my laptop to my emu, and a popup came up "Import data from emanage" and i clicked ok. My question is, does this reset the emu to a default tune? is there a way i can confirm or see if the car is still tuned?
2) the datalog function, how do i read it? or what can i see ? can i check if my airflow sensor(maf) is faulty through a datalog?
appreciate any advise. this is a brand new world for me.
When u connect to the ecu,u will see everythings there. Since the tunner not locked the maps.
U can see all sensor input run when u datalog the ecu while ur engine running. Actually the datalog use for tune not for read fault code..http://ts2.mm.bing.net/images/thumbnail.aspx?q=1308761990109&id=81e44e6d00c5c2fc71af20ec25847f47
bro the pic too small i cant see anything. but i thought there was a way you can read the signal reading or something like that to indicate something that is abnormal?
Ofcourse if u know how to read the actuall voltage before it become abnormal..
http://image.turbomagazine.com/f/8740211+w750+st0/0708_turp_09_z+gredd_v_manage_review+software.jpg
ok, so bro is there a standard voltage expected out of the sensors to be considered as normal or abnormal? in particular i need to know the afs.
OK. what is ur problem actually? Standard voltage of sensor depend at what kind of ur engine use.. Normally for hondas map sensor will read at 0.50volts at-12.8psi/meanwhile at full throthle it will read 3.41volts at 2.7psi. If i not mistake.
sometimes when rpm reaches 5k-6k cant climb anymore...like cant go.. engine is 4g63t ... want to check if my maf is faulty or not...
the emanage using long time alr bro... recently only this problem happened. engine light not on...as i know..maf sensor starting to have prob might not have engine light still can be problem...thats why i want to use the datalog function to see if i cant identify if there is a problem there to make my troubsleshooting easier.
bro ... before doing the datalog run tonight...i cleaned my MAF(afs) and washed my filter, re-installed... tested the car and did a datalog..but the problem is gone... doesnt hesitate anymore.... so i think my afs was the issue.... thanks bro for your help.
the problem started again last night... rpm 5k+ rpm...will hesitate.. i think maf sensor problem.
halfcut ah bro? i check with bintang brand new maf #286 1.2k.
your link is for ignition harness bro, i need the 3 bar map sensor right?
