emanage tuning and installation
Greetings to all expertise there, im currently using a stock 4g92 sohc... does this engine have the potential to increase hp if i put e manage ? my engine had slight mod example like exhaust 4-2-1 and larger piping,some power plug cable and a fuel regulator. Any expert there bcz i plan to put in an emanage package . ?? any sifu ? :( seriously very hunger for hp now...probably i will put an adjustable cam pulley...
A quick E-manage question...
If I want to test reverting my car back to stock ECU mapping, can I just unplug the E-manage blue from its wiring harness? Will there be any ill-effects from this?
The car is all stock except for air filter and exhaust.
long time no c bro... go general talk got a topic for us old kakis ;)
advice needed.
buying an emanage what is suppose to be in the package
what is an optional and important purchase for tuning purposes ( b16a )
where is the cheapest right now as i wanna do installation at my own shop..
besides emanage what is a good option ?
Hi all.. I got check engine lite on my meter, after checking all my sensors ( o2, etc) eveything ok.. Then i disconnect -ve trminal of the batery, n connect it back after 30nd, the check lite is gone.. Is it mean my emanage got reset too?
advice needed.
where can i get it cheap ?
Wanna ask, if E-Manage already tuned and I need to change my car's battery
Does disconnecting the battery resets the tuning done in the E-Manage?
a noob question here
M7 em-con and Greddy e-manage blue version is the same 1?
got any different?
can copy the blue version setting go to em-con?
its the same.
u alr got blue wanna change to em-con?
if you wanna copy another cars setting to your mcon is not advisable bro...every car not same tuning.
its the same.
so the blue version is same with em-con but i saw the blue version can tune outside the console there but em-con cannot
nop, i just wanna get 1 but i saw lot blue version like imitation 1 so i would like to get em-con
so can use the e-manage software to tune the em-con?
if the engine is same model and same spec can use back the setting of that car?
You can even tune the emcon with a emb software. Same engine same spec, different condition as in bore wear n tear, carbon accumulation affecting compression ratio. But just pray that ur engine will last for saving over RM250-RM300. Good luck..
If my car stock ECU & now the A/F is 14.7, if I install the E-Manage Blue or any piggyback & tuner set it to 12.5 A/F.
My question is:-
Will the stock ECU will control & back the A/F to 14.7 even after tuner set the A/F to 12.5? What I mean is the A/F setting will back to stock even with piggyback ECU???
Or once we set the A/F with piggyback, theh A/F will remain 12.5 all the time. Need advice as I heard from others that the stock ECU tends to go back the stock A/F even after we install the piggyback ECU...
