Emanage Blue help
flatlander525
guys..
using emanage blue on mazda BPT 1.8 pressure reading from 3bar map by V
my problem is why WOT ( wide open throttle ) detect only 30%.?
previously done tuning but after overhauling my engine and still remain the same setup but my WOT now only detect 30%
how can this happened? and what will happen if i still remain thin 30% of WOT? and how the reading becomes in my EMB.
how to make it detect WOT 100% back?
need somebody troubleshoot this prob for me plz..
Thanks
if dat doesnt solve it, try feeding 5volt to the emanage tps wiring, see if it increases the reading to 100%. if it does, its either the tps power supply or the tps itself is fecked up. please check and report back
ok i just reset the WOT now detect 100 WOT but now idle WOT reading 30% ayakkk why?
engine must running only it can detect WOT if not cannot detect...
in that case, u must recheck the wiring tapped at ur ecu, maybe u should change ur tps sensor. u just turn on the ignition and full press ur acclerate pedal and click O.K,that's all. No need to calib at the idle !!
