Electrical Knowledge: Did You Know ??
yeehau86
Moderator
Helmet Clan
Moderator
Hi everyone!
Do you know what contributes to your monthly electricity bill?
For those in Semenanjung Malaysia , TNB’s tariff is approximately 30 sen to 45 sen per kilowatt-hour (kWh), depending on your usage.
The more you use, the more expensive the rates!
Below is a short table of common electrical appliances, and a rough estimate on how much they cost to run for every hour.
(The cost may seem low, but remember, even using 3 sen/hour means that you will be paying about RM 20 a month if you leave it on for 24 hours a day!)
Appliance
Estimated cost (sen/hour)
Fluorescent lights
1 sen
Wireless Router
1 sen
ASTRO decoder + dish
2 sen
Table Fan
2 sen
Incandescent lights
3 sen
Ceiling Fan
3 sen
Computer (laptop)
5 sen
CRT (‘normal’) TV (21 inch)
3 sen
LCD TV (32 inch)
7 sen
Computer (desktop)
9 sen
Plasma TV (42 inch)
10 sen
Washing Machine
15 sen
Vaccuum Cleaner
17 sen
Electrical Clothes Iron
33 sen
Electric Hot Plate
46 sen
Air Conditioning
46 sen
Electric Water Kettle
50 sen
Hope this helps. :wavey:
---------- Post added at 04:44 PM ---------- 6 hour anti-bump limit - Previous post was at 12:55 PM ----------
For air-conditioning my list don't have, but it will be the most expensive charge.
The most electricity consumption is not while they are on. but at the moment that there are being switched on. Generally, on/off a light for 5 times, it will cost more money than on 1 time for 3 hours. Need improvement on time management or else, suffer a bit :biggrin:
Example, let's say 40" and consume about 270 watt. Put away the power surge during switched on, it will consume slightly more than 1 kilowatt (or 1 unit) per 4 hours. Means that RM0.45 / 4 = RM0.11 or RM0.30 / 4 = RM0.075 . On other electrical appliance, just check the watt consumption at the back sticker, use the below formula to calculate the consumption per hour:
(watt /1000) x electricity cost per unit.
