EK9 Loaded
Interior
- EK9 Original Red RECARO seat – Driver & Co-Pilot
(No Black2 marking & only small Butt lying)
- EK9 Rear Seat
- EK9 Type R Carbon Meter
- EK9 Small Red carpet, Middle back (All 1 round)
- EK9 Big Red carpet (Together with Marking Type R)
- EK9 Based Red Ground Carpet
- EK9 Red Door Trim
- EK9 Dash Board, Air Cond. control Panel, Outlet, 1 whole set
- EK9 Gear Knob c/w short shifter
- EK9 MOMO Steering c/w Airbag
- EK9 Double Din Player holder, Hazard Light, Air Cond (Carbon Fiber)
- EK9 Safety Belt Lock (Front & Rear)
- Omori Meter Gauge
- Clean interior as I don’t smoke.
Exterior
- All Round complete convert to EK9 98 spec
- Spoon Yellow color c/w Carbon Fiber part
- Carbon Fiber Front Bonnet - Spoon
- Carbon Fiber Back Spoiler - Spoon
- Carbon Fiber Side mirror – Spoon
- Standard SO4 absorber,
- EK9 Flat Black Door Visor c/w Screw cover
- Smoke lamp (Head Lamp Polish)
- HID 4300K Ballast white projector Lamp
- Raybrig sport Yellow fog lamp.
- EK4 Sun Roof c/w Inside Cover. (Optional)
- Carbon Look Plat No (Front + Rear)
Engine / Management
- EK B16B Set up
- Jun CAM Stage 2,
- Crower Valve Spring & Retainer
- B20Block port & polish head ++ Crankshaft, Con-rod fully Balance & Lightened
- EK9 ECU, Clutch
- Carbon Fiber Plug Cover
- ULTRA Silicone 8-9mm Red Plug wire
- Works Adjustable CAM pulley
- Full wiring Convert to OBD 1 (EK9)
- HKS Open Pod Air Filter c/w Stainless steel intake outlet
- NGK Iridium Spark Plug (Running less 1000km)
- Engine Oil Semi Synthetic 10w 40 (Running Less 1000km)
- Super 90 throttle body
- LSD with FD 4.4
- Management by VAFC II Black CW Front Holder
- Double layer Aluminum Radiator c/w Silicone Hose all round
(SAMCO Sports + AVW hose)
- B16B Type R gearbox with 4.4 final drive
- EK9 Intake Std. Manifold bore to 70mm oversize
- H22A Injector.
- Extractor 4-1 c/w Stainless Steel 304 Jasma Roder Bordermax 2.5’’
(True Raw V-tech roaring)
- Sard Adjustable Fuel Regulator
- Apexi Pen Turbo Timer.
Handling / Others
- Skunk 2 Front strut Bar
- Skunk 2 Lower left, Right, Middle Rear
- EK9 anti Roll bar rear bottom
- CUSCO rear monkey bar (I don’t like to use this words but Rare)
- Vtec Open at 5800, Close at 5000RPM.
- EK9 5 Nuckle set Handling
- EK9 Font, Rear Rotor, Caliper, Brake Pad
- Rays Engineering Volk Racing Wheel light weight for competition
(Gold Bronze) ORI Japan with Stickers TE37 5 x 114.3 x 7jj
- Spoon Brake Tank, Brake Fluid Cotton Cover (Blue)
- Tyre Brigestone Yokohama RE 001 Adrenalin (70%).
- HKS Hot Earth Grounding Wire
- PIVOT Mega Rizin voltage stabilizer
Reason For Sale :
Car has NO problems and is a weekend @ monthly car.
Test drive only for the buyers that i trust.
Available to call at 019-7752679 for the deal.
JB town area
weekdays 8pm – 11pm
Weekend 8am – 10pm
Interior
- EK9 Rear Seat
- EK9 Red Door Trim
- Omori Meter Gauge
Exterior
Engine / Management
- EK B16B Set up
- Jun CAM Stage 2,
- EK9 ECU, Clutch
- LSD with FD 4.4
- H22A Injector.
Handling / Others
Reason For Sale :
JB town area
weekdays 8pm – 11pm
Weekend 8am – 10pm
