ek9 diskbrake rotor
civic18c
all members...
could u know what diskbrake can fit to ek9 knucle? because my ek9 diskbrake getting bengkok 2 times got to skimming still not perfect when brake around 1++km the steering jarred. asked formen they anwser my diskbrake rotor bengkok.
so any idea for use another diskbrake?
because difficult to find just ek9 disbrake rotor they want to sell 1set front and rear with knucle.
all members...
don't change the knuckle....change the rotor only!!! DBA gold rotor or project miu
all members...
I got brand new discs from DBA and EBC with matching brake pads from EBC.
hattech-v said:
shiro u got rear only?
hattech, i just order the rears only from EBC UK. Let me know if you need to reserve them :_:
all members...
Actually the jarring happens at really high speeds whether you like it or not.. it's not the discs, but the EK9 pad compound which comes off in pieces when it get's really really hot.
I once tried a braking test 180-0, and felt the juddering.. and it retained the juddering for quite a while too when I finally slowed down to a stop. checked the discs, can see some pad material stuck on the discs.. a couple of brakings cleared it up, and the brakes returned to normal.
As for anything below 120kmh.. no problems whatsover..
bro actually fist time do the skimming at mechine shop, they do wrong skimming and the dis rotor got gelong. when i drive my car heard some thing wrong and i go back to michine shop they asked wrong skimming and do second times skimming. after that they as a normal but not maintain long time they come juddering when brake 1++km. i check the brake pad no material stuck on the disk.
anyway thanks for ur suggestion.
i face the same problem using ek9 rotor n knuckle!!!! cannot tahan panas n hujan!!! damn lazy n no money to buy another set!! currently i'm using DBA but still the same after few month!!! the disc easily warped after kena hujan
Strange.. my car is daily driven.. and those that know me probably know exactly what mileage I do in a month, in the sun, the rain, and other conditions.. No problems with disc brake warping also..
Stock EK9 discs.. never skimmed. :P
I think you guys slam on the brakes too much la... :P
