ek3 d15b gearbox
kampung_boy
all sifus, help me..
Other than ori multimatic gearbox,any gearbox that can fit my ek3 d15b engine. Start to jerk already. Heard that ek3 gearbox expensive. Love the engine,mileage just 78k(got from rich chinese old lady,go to market only for the past 9years with her),engine still blink2,spare part easy and cheap. Just the gearbox spoil my mood. TQ:bawling::bawling::bawling:
If i have not mistaken, gearboxes between D-Series engines are exchangable between D-Series engines...Of course, you can't put in a better gearbox such as from the B-Series (which is expensive too, IMO), but at least you do not have to stick to the multimatic gearbox if you feel that it is expensive... Maybe you can try sourcing your gearbox from D16Z6 (JDM Sohc Vtec), or D16A6 (Non-vtec engines for our local Civic EG)... As for the process and what else that MIGHTneed to be changed (mountings, etc, example onli..), I am not sure... A good Honda specialist will be able to tell you more in detail.... Good luck
The B16a AT gearbox (EG6) has the code of M24A, the D16Z6,D16A8,D16A7 & D15B2 AT gearbox also uses the same code gearbox M24A.
But I'm not sure if they can be swapped around between the D & B series...
