for B18C-R around RM5k including install just for the engine and head. u can reuse everything else though id recommend getting the B18C-R intake manifold and throttle body....or maybe skunk2 intake manifold and skunk2 alpha 70mm throttle body.
yes jpj still can approve.
after install you need to re-tune ur engine. if ur ecu is still stock oso... then get Crome....which is basically a custom chip.
Sifu mADmAN,
Why skunk2 alpha tb instead of S90?...Let's put budget issue aside.
TQ
As long as the new engine displacement does not exceed 25% from the previous and no welding done for engine mounting. Guess jpj should has not valid reason to reject.
If I am not wrong, that 25% rule works something like this:
Lets say EG/EK factory displacement is 1600. so, 1600 X 25% = 400. And so, 1600 + 400 = 2000.
So, K20 can be used in a EG/EK.
Eh, if like that, that means Putra, Satria GTI and Wira 1.8 (C99) should be legal to transplant 4G63T isn't it? But why everyone is saying now it is illegal to transplant 4G63T into proton cars other than Perdana?
It is a special rule that ONLY applies to Proton. Anything that is NOT a Perdana or Lanspira CANNOT have 2L or larger displacement engine.
This site details it very well
http://www.myviturbo.com/2012/01/how-to-endorse-your-change-of-engine-with-jpj-puspakom-inspection/
not all EG/EK are originated with 1.6 liter engine bro, what about EK2 (1.3 liter) / EK3 (1.5 liter) originally? I guess what ixeo said is right.
But those 1.3 and 1.5 can be endorsed to use B16A or B16B isn't it?
for B16 should be fine, my concern is plonk in a K20
