EF Customs - Absorber and Springs Servicing & Mods
EFN
Dear All,
My latest offering are as follows:
- Coilover springs installation and modification into non Coilover dampers - RM50 each dampers
- Dampers servicing (replacement of Hydraulic Oil and seals) - RM50 each dampers
Coilover Springs available:
TITAN
2, 3, 4, 5, 5.5 and 6Kgs - RM80 each NEW!
Hydraulic Oil used:
- Castrol High Pressure RM10 for two dampers
- Motul Sports/Competition RM30 for two dampers
Options:
You can send your car to me and it will take half day to complete. This way removal and installation will be charged at RM10 for 1 absorber. Or it will be better if you just simply send me your absorbers and of course no charge will be inccured.
Applicable to:
Any absorber/dampers that uses bolt type screw at the body to hold the shaft like Corolla/Levin/Trueno AE111 and AE101 Japanese dampers.
Note:
If you go for Coilover Spring mod, it will not be height adjustable - just that I will modify the "plate" holding the springs to accomodate small diameter coilover springs. And height will be set at preffered length during the modification itself. Advance appointment is required before you send in the dampers.
Important NOTE!:
Applicable to all Oil and Oil+Gas dampers only. Gas dampers cannot. For Oil+gas dampers it will be 100% Oil damper after servicing - and I can confirm that the result will be quite satisfactory even with Oil only (I am using a set now)
For more info just call me at 012-240 7780
bro..
i want my car to be rally look..can aaa??kasi tinggi sket front n rear..than i wan change the spring for all the absorber...front abs is ae92..rear is kyb sr...can aaa??how much??mana bikin itu abs...at ah pau shop kaa...ke suriani???:cyclops:
conflict_tuning said:
bro..
Sure! rally look can! but I have to see first if your dampers can be modded. It will be done not far from Apau's.
Yes.. .. Finally new EF Custom Mod is out!! Gonna call you soon.... Wanna change my front damper oil.. .. ..
Brother EFN,
still not sure what you are talking above.. ^_^ sorry r.. but the price is nice and my car is sort of soft during corners... see if I see you next time on gathering hopefully u will explain to me in more detail le.. ^_^
Aloo frens, sorry for late reply. Was busy yesterday at office.
Anyway, Superstrut is also servicable if the shaft can be removed from the casing.
Hi EFN,
Would like to ask......
Can my Adjustables Hi/Low be serviced or something to make it softer abit?
maybe reoil or service or someting..........U know my abs rite(u hav seen it before) TEIN..............
Thanks man
sifu EFN, absorber TOSER can do or not?
my rear one leaking la, if can i gonna reoil n not change it.....
thinkin should i change to titan or not, so far no one can do TOSER, kakakak
