Ecu tuning or reflash
ckwanloong
Like the topic~ share with us like what ecu u r using? Where and who to tune? Cost ? And the result~
---------- Post added at 09:20 PM ---------- 6 hour anti-bump limit - Previous post was at 09:07 PM ----------
As I juz throw in two "tebu" cam and now the engine need to be tuned to make it smooth otherwise like now is worsen than ori. I would like to share what I have done:
Td05 from evo 4
Fmic
Denso iridium
Custom exhaust system~ after downpipe with 3 inch stainless steel with bullet and muffler
Forged racing radiator
Works fuel regulator
Works adjustable cam pulley
Tomei 260 procam with valve spring
Sard 265l fuel pump
Greddy profec-b boost controller
Like this mods I hope I can get 280whp~ but I'm not sure our stock engine and gearbox can tahan or not.
So who and where is the expert to tune our trek? Does ah Wah tune? But I'm from JB~so far away and im sure my car now can't go for too far ~
---------- Post added at 09:22 PM ---------- 6 hour anti-bump limit - Previous post was at 09:20 PM ----------
I forget the banana with tial 38mm wastegate
---------- Post added at 09:25 PM ---------- 6 hour anti-bump limit - Previous post was at 09:22 PM ----------
Evo 560cc injector~
Td05 from evo 4
Fmic
Denso iridium
Sard 265l fuel pump
Evo 560cc injector~
Hi bro,
What's the problem when U said "......like now is worse than ori"???
I'm guessing U're running too rich because U've uprated your fuel pump, injector, increase your fuel pressure. Is your fuel consumption very bad too?
Avant bro, my fuel pressure is now set at 3.2. I'm running on rich mixture since the valve lift is higher, the engine suck in more air fuel mixture.normal running is ok but when u press the gas deeply it become like miss fire and white smoke come out from exhaust. Where did u tune ur car?
---------- Post added at 08:07 PM ---------- 6 hour anti-bump limit - Previous post was at 08:00 PM ----------
The cam was taken out from my friend's Evo since he upgraded to 280. As he said last time he had my problem too, after he threw in a tomei ecu and tuned then only run smooth. So I wanna tune mine too. I've asked about sg Airtrek club, most of them send to a Airtreker too who tunes Airtrek very well, but he is oversea now and would be back on 23 Dec. I think I can't wait until 23 dec before my spark plug get wet and wet again.
---------- Post added at 08:09 PM ---------- 6 hour anti-bump limit - Previous post was at 08:07 PM ----------
Chubster bro, where exactly the Dom Motorsport is?
bro, i from jb too, u can find Sky, expert tuning in airtrek, last month i purposely drive to KL and find him to solve my airtrek problem. Development of motorsport u can search from Facebook.
ckwanloong, sorry bro still remember last few day one silver airtrek cucuk u at sutera ? that slow airtrek was me haha... ur car quite powerful, i know some former airtreker members. we can TT together.
Oh~ that was u! Ur car is fast too!where do u live? U purposely followed me or u live around here?
---------- Post added at 11:30 PM ---------- 6 hour anti-bump limit - Previous post was at 11:29 PM ----------
Btw, how u know that was me?
i was fetching my friend go home, i also live somewhere around there. only few airtreks around that area, so it quite easy to notice. my ride stock only la....
There is another two red Airtreks around here, one is wny6121 and wlc48.btw i'dnt seen ur silver baby around here b4.mayb we should have a tt session later after my car is done.
my car only appear morning go to work and night come back from work haha...no problem, i try to inform other members.
bro which evo camshaft u using .....your problem same as my problem
after i change evo8 camshaft like running not smooth like original camshaft correct ??
Td05 from evo 4
Fmic
Denso iridium
Sard 265l fuel pump
Evo 560cc injector~
with this set up you should can go more then 300whp . call Sky sifu to help you set up the ecu should be every thing fine . Note: Oem GB can hold 300 whp ...
Ic...then I better stick in 280whp...safe
---------- Post added at 08:42 AM ---------- 6 hour anti-bump limit - Previous post was at 08:40 AM ----------
Bro yung, I,m using tomei 270. How did u soft ur problem?
The only thing you can do is . Flash the ecu or add in some add on ecu .bout the GB ~ no worry ~ just need bout extra 5-6k . Then you get can last for 400whp GB . Lol . Or go for manual trans . :driver:
