ECU, EMS and Piggyback..whats the diff?
basahboy
Ok sifu's i need an understanding on the above title...
Whats the difference between the three above...
- When i meant EMS is like APEX FC, AEMS, MICROTECH, HALTECH, etc.
- When i meant Piggyback is like Uninchip, Emanage, Obit
- When i meant ECU is like MUGEN, Spoon ECUs (NOT CHIPS)...i saw that they are selling in motortrader for 1.7k...worth it???
I am contemplating which i should choose from to complement my rather mild type r set up.
Thanks...
Apexi FC consider piggyback mah... no?
if i were u i'd rather go for EMS like haltech.
i think difference on these 3 category is - up to which limit u can do on the setting side.
means more function.
Thanks...
What 'difference' are you looking for exactly? In general:
- EMS = Engine Management System? Any add-on device that electronically manages the engine can be considered EMS (i think). This would include piggyback units.
- Piggyback = Overrides the current ECU settings. It is plugged into the ECU and overrides certain settings in the ECU, based on what sort of device you use. E-Manage, VAFC, SAFC, etc are all piggyback as they need to be tapped into the ECU to function. The level of tunability would depend on what sort of device you use.
- ECU = Well, this you would already know. It plugs in directly into the engine wiring. Difference between this and a re-chipped ECU? Quality of the hardware inside and the 'originality' of it (so I was told). One ciplak, one ori. But I believe there is more to it than that.
