E7/8/9 Brakes
audetom
read while you still can
Bro, just wondering...maybe stupid question here...
can brake system from Evo 7/8/9 plug n play to Lancer GT...?
seen lot of them at chop shop nowdays...
thanks...
if im not mistaken, "yes" since it share same knuckle, jus maybe ur rim cant fit coz d offset n rim clearence can fit it... jus my opinion, dun shoot me if im mistaken...:thefinger:
If you said Plug-n-play for new Lancer GT... answer is NO. You need to custom the bracket for it. Beside that, make sure your rim offset is good enough to clear the caliper.
if u use evo10 caliper will be no prolem..but if u use evo5-9 brembo caliper ..alot of thing u have to do like the bracket for caliper n the difficilt is the rotor..u have to fine a big rotor to fit the knucker ,,a lot thing to do ..bro...better order a vttr 6pot more cheaper n easy to install.haha.n not expensive too...:wavey:
yeah.. i saw a lancer gt with vvtr caliper and then sprayed it red with brembo word on it.. actually looks quite nice...
Hi sifus, I'm a LGT owner and recently purchased a set of BBKs taken from Airtrek. The rear 2 pot brembos can't seem to fit into my back due to different brake shoe size/design. Any idea if I could custom/machine a new shoe to fit? Front brakes are fine tho.
Any help is much appreciated. If there are any good workshops, pls refer too. Tq
