E manage removed for safety
keanenexus
Hi all ,
would like to ask this .
If i were to park at a deserted carpark which can be exposed for car thieves,
Can i remove the E manage as the thieves cant start the engine ??
Will the setting run when i re-plug them onto my car and start the engine ?
just last night i was told by a friend. a car owner took out his ecu +emanage. thieves came, plug masuk spare ecu, ciao
everyday want to take out and put in ecu is to much hassle for security sake...better invest properly like proper alarm,immobilizer and such...but even that doesnt protect a car from being stolen...
car with no engine also can be gone if they come with a tow truck... f&#^@*ing thieves :thefinger:
well if they use spare ecu, surely the car must be almost stock standard.......if the car were upgraded with injector, fuel pump, larger afm, larger tb...hardly a stock / spare ecu can compensate at the place.....but still vulnerable to towing....:thefinger:
i will get back to u guys asap on this, iirc it was a hundred plus kit jugek ler, not exactly sure for now. it was years ago since it was fitted in
