PAHAM Known Member Senior Member Jun 24, 2009 #1 Which one management is cun if i want to put on my engine (evo 1) e manage or apexi afc neo...
L liz@rd Known Member Senior Member Jun 24, 2009 #2 both also can , but emanage is better , can do more searching on the pros and cons on both items here
SkYwAlKeR Over 10,000 RPM! Senior Member Jun 25, 2009 #3 i heard afc neo tend to overheat after long hours of use... mayb because of its extensive GUI features... emanage better... only downside is u need a laptop and software to program it... with safc u can tekan as u wish...
JINEIL2EN Over 10,000 RPM! Senior Member Jun 25, 2009 #4 AFC Neo la... cheap & hassle free, atleast dun have to heret by other ppl...:proud:
zarique Known Member Senior Member Jun 25, 2009 #5 afc neo have ignition and injector function to modify like Emanage harness..?
JINEIL2EN Over 10,000 RPM! Senior Member Jun 25, 2009 #6 zarique said: afc neo have ignition and injector function to modify like Emanage harness..? Click to expand... no.... hehehe....
PAHAM Known Member Senior Member Jun 25, 2009 #8 thanks all i decide to put e manage where can i find the best tuner and installation.
JINEIL2EN Over 10,000 RPM! Senior Member Jun 25, 2009 #12 got so-called best tuner for emanage meh..???:hmmmm:
veilsideboyz 1,500 RPM Senior Member Jun 27, 2009 #13 Anyone here changing piggy from safc/PCIII/afc neo moved to emanage blue ?? or emanage moved to safc/afc neo/PC III... how many hp you drop ? or gain ? Please Share Out ! :) thanksss for help !!
