driveshaft question
my ride got 'kruuuk' sound when i take a corner and i can feel the the accelerator pedal can feel not so smooth during that time. does anyone know what is the possible cause?
Should be driveshaft if sound only comes during corner or especially when making U-turn.
i have a questionnnn :nurse: need you guys' pro-ness in this:
im driving an iswara, and i suspect my draftshaft and/or bearing is faulty.. when going in a straightline with heavy load, like going uphill or taking off with 4ppl on board, i could hear kreeeeeeeeek sound.. once the car pick up speed n momentum, no more sound already..
d/shaft doesn't produce any sound when turning. perfect.
What could be the cause? and sorry to TS if i hijacked your thread.
ya, only during corner. i also suspect it the driveshaft but when i asked my trusted pomen to test drive it, he said my drive shaft is ok.
Weird, 1st time hear such thing but hard to imagine the sound with words.
Best get it check? Either that just something lose since is proton :biggrin:
Like my blm. Once got sound behind, Get it check, is the rear absorber problem.
Try to make a U-turn to be sure. Usually if sound not that loud they will ask u continue using.
Loud only change.
Bro. john,
test by doing right full turn and left full turn, like coming out from T junction. If got kruuk kruuk sound then drive shaft problem
Cornering may be bearing problem...
---------- Post added at 07:33 PM ---------- 6 hour anti-bump limit - Previous post was at 07:32 PM ----------
Should be something else but difficult to say without actually testing it.
Loud only change.[/QUOTE]
Bro. john,
Cornering may be gearing problem...
thanks bro, if like that than its confirm the driveshaft but the sound is not loud yet. the sound only occur when entering junction, not during cornering.
If only on full turn then still can use for the time being....
alrighty.. will get it checked..
p/s: my rear absorber got 'klonk' sound if take corner, like a tong kosong sound, but only happen sometimes.. is it serious? or just a bushing issue?
