general settings??Originally posted by kher@Dec 7 2004, 01:31
wat r the suspension settings to prepare a car to drift?
-shock absorbers for front n rear?
-springs for front n rear?
-sway bar for front n rear?
-ride height for front n rear?
-brake bias?
-downforce for front n rear?
sori for such noob quest... :P
how bout FF cars....i onli lowered my springs...wat should i do to ass drag nicer.... :(Originally posted by fabianyee@Dec 8 2004, 00:46
set near anti-roll bar to stiff. positive camber at the rear, negative in front.
stiff set up at the back, front soft to medium...
when you take corners with the rear on stiff setting, the rear will 'slide' instead of leaning on the outer rear tyre. Making it more condusive to drift..
FYI, if you set the front too stiff, it'll understeer.
