Ever want something different? Something new that no one has, yet? Don't want to risk buying fakes?
A brand new generation of performance parts have reached zth!! These are from Australia and they're close to flawless in terms of performance, quality, and reliability.
These digital gauges are one of the most responsive meters in it's categories, comparing to Def Rep, Jasm meter, etc ;).
Introducing you (drum rollsssssssss), items from Drift Performance!!
[YOUTUBE][/YOUTUBE]
Item(s):
___________________________________________________________________________________________
Boost Meter - RM460.00
- Up to 30psi / -30In Hg
- Large Numerical Display
- Blue Digital Display
- Available in Red
- Includes Fitting Kit
- With Electronic Sensor/Sender
http://www.shopdrift.com/content/images/elec_irid_turboboost_full.jpg
Volt Meter RM350.00
- Reading from 8V to 18V
- Available in Red
-Includes Fitting Kit
http://www.shopdrift.com/content/images/elec_irid_voltage_half.jpg
Oil Pressure Gauge RM380.00
- Reading from 0psi to 150psi
- Available in Red
- With Sensor
*Adaptor Not Included
http://www.shopdrift.com/content/images/elec_irid_oiltemp_half.jpg
Oil Temp Gauge RM350.00
- Reading from 50C to 150C
- Available in Red
- With Sensor
http://www.shopdrift.com/content/images/elec_irid_oilpressure_half.jpg
Tachometer 5" w/ Shift Light RM620.00
- Operates on 4, 6 or 8 cylinder engines
- Ranging from 0 to 12k RPM
- Includes L.E.D shift light two stage
- Designed to be used in dash
- Compatible with any type of ignition systems
- Programmable shift point
- Large digits for maximized readability and minimizes high speed distraction
- Blue digital display
- Multi position bracket
- Includes fitting kit
http://www.shopdrift.com/content/images/elec_irid_taco_on_full.jpg
Water Temp 52mm RM350.00
- Range from 20°c to 120°c
- Electric sender
- Blue digital Display
- Available in Red
- With Sensor
http://www.shopdrift.com/content/images/elec_irid_watertemp_full.jpg
ACCESSORIES for above :
Water Temp Adaptor 32mm RM49.00
Water Temp Adaptor 34mm RM49.00
Water Temp Adaptor 36mm RM49.00
Water Temp Adaptor 38mm RM49.00
Works Engineering Oil Temo Adaptor RM130.00
Stand : RM50.00 (Not included for each meter purchased, only included for Tacho 5")
____________________________________________________________________________________________
Adjustable Fuel Pressure Regulator RM289.00
- 1:1 Rising rate
- Turbo & N/A applications
- 1/8 NPT service hole for meter
http://www.shopdrift.com/content/images/fuel_freg_regulator_angle.jpg
Liquid Filled 100psi Fuel Pressure Gauge RM50.00
http://www.shopdrift.com/content/images/fuel_fpg_100_front.jpg
Dealing method: COD / Postage Via CITYLINK RM15.00, up to 3kg
Location of seller: Sunway
Contact method/details: 012-9096996
Warranty : 1 year against defects
Age of item: Brand New
Reason for sale: Trader
[YOUTUBE][/YOUTUBE]
Item(s):
- Available in Red
Volt Meter RM350.00
- Available in Red
- Available in Red
- With Sensor
- Available in Red
- With Sensor
- Electric sender
- Available in Red
- With Sensor
- 1:1 Rising rate
