Double Signal with Switch
ryukeong
Hi there,
Does anyone know how to do 'Double Signal' that will stay on (Front & Rear) with switches to control on/off. And it will still blinks when u use the signal.
try use the search button.... i guess we had discussed this numerous times already....
if u wanna save the hassle, ask acc shop to do it lo... shouldnt cost u alot since it is done by tapping some wires.....
Redline_club said:
sure got le, now our signal bulb is 1 leg ma, brake bulb got 2 legs, i do it at my wira...
You got installed it with switch too?? Izit you diy or do at acc shop? How much u had used to get it done?
IMHO, if you wanna do this, why don't only use the side signal? If you use front and rear, people might misunderstood you thinking that you want to take a junction or change lane. They might think that your signal is broken (since it is not blinking). Imagine if some one is coming out of a junction and saw your front signal to the left Or both is on, he might just come out of the junction and bad things can happen right? People might also assume you're switching on your hazard light and try to overtake. Normally, hazard light is on when the car is stationary (due to failure etc).
wont de, hazard on in low le, whn we put signal it will blink, kl many ppl do le...
seriously, it's dangerous...they do tat cos they are noob about wat is signal light...so do u?
That dosent make it legal or right.
When you drive, you dont stare at signal light of the car in front of you. You just glance at it, and act accordingly. I'v encountered some of these cars before, it can be very dangerous and sometimes not at all.
