door warning light...
xmrtass98
guys...im having this problem...the doors warning light..is ON even when all the doors properly shut...
only the warning indicator light OFF when i startted the engine....it comes back to normal...
problem occured when engine is off...shut all the doors...ON the alarm...the warning indicator light still ON....
what seems to be the problem...is it the wiring problem...already tested all the doors point button...push it several times and monitor at the warning indicator lights near the dashboard...but still got prob....
do need ur help guys...much appreciate it...
happened to my friend's wira aeroback before .. the light on but it seems dim .. engine off .. doors closed .. but the light still on but dim .. try few times .. open and close .. close and open .. alarm activated .. but still can see the dim light .. at the end .. it suddenly disappear like that .. OK until right now ..
curious and still not know why like that .. hehe ... X FILES case going to occur ... :P
hmmm.....have u guys checked thatall the door sensors are working??
if all that does..............
it happened last time to my FTO...i drive drive suddenly double signal keep flashing(alarm flashes double signal when a door is opened)....wa lan....damn malu lohz...driving along the street ppl keep watching...maybe some thinking wat the hell...this fellow thinks his VIP or wat....
i then when to the accesories shop to 'tiao' that fellow....he check check guess wat.,...its the 'front bornet' sensor...loose liaoz...
guys...i'm long winded sorry...hope this one helps....
doors sensors already checked...
front bonnet...not yet...
will dignose the prob this weekends...
too BZ nowdays...at work...
anyway TQVM for the comments... ;)
