diy paint dashboard panel
eddie368
sifu out there .... i just spray my dashboard panel from wooden panel to black.
the result of the color is the upper wan nice la.. but the lower near the lighter area
looks cacat... got pimple around.. y this happened got any solution?
if i wanna do it again.. can? I mean sand paper the panel n respray. means smooth out the
whole panel n spray.. tq
u should refer the older post, which is just a few post below u... search first.
http://www.zerotohundred.com/newforums/showthread.php?t=36408
anyway, the bubbles, maybe coz u didn't clean your surface properly when u diy. Try sandpaper it off... all of the pain.. remove all stains, uneven surfaces, scratch, till itz smooth... then only spray, and when u spray, spray it evenly at all surface from a same distance.. then only u can get even colour.
o hyea, make sure one layer is dry already then only proceed to 2nd layer.. same goes to 3rd layer. Dont spray another layer on top of wet layer... u'll get the 'saliva drooling' effect or bubbles.
