DIY install Voltmeter
khguan
4,000 RPM
hi Guys n Gals...
i bought a autogauge voltmeter few days ago.. i tot the demeter come wit a mounting bracket.. but i was wrong...
so i went around my place to find for a bracket or cup or something... found one acc. shop.. bracket rm55, cup rm45.. wah... damn so expensive.. my meter onli rm120.. not worth it to spend so much on mounting.. i dun wanto install pillars.. very chor teng cos i onli got 1 meter
this is the bracket wit the meter... not yet installed..
last one... closer view... de meter i stick wit black matt sticker around it.. then de steel band i sprayed it balck... some parts need touch up.. i just use black marker pen to make it black..
total cost of mounting bracket material = less than rm2.00 :lol:
time to complete installation = half a day :mellow:
altho very tiring job doing de wiring.. but satisfaction is great!! :lol: B)
yah.. i forgot to mention.. de power i just tap from de cigarette lighter wire.. so need to dismantel de HU console to connect de wire...
this meter got 5 wires.. 2 red, 2 black, n 1 orange..
connect de 2 red wires together... then connect de 2 blacks together.. orange no use..
so now consider got 1 red n 1 black.. u can now connect them to de power source.. red to +ve.. n black to -ve..
Originally posted by khguan@Mar 22 2005, 22:42
erm.. i duno wor.. this meter is from taiwan i think.. it will be ok kua..
[snapback]831866[/snapback]​
hmmh... u got multimeter also? can use to test ma, tap the multimeter and on ur car, then see whether same in the reading... hihihi...
btw, y must tap at cigarette wire ar? can tap at other place? i scare it takes the reading from the cigarette wire is not so accurate....
sorry, i still very new in this... :P
i will check when got time..
yah i also got think bout dat b4.. well. i tap at de cigarette lighter cos easier mah.. very tired making de bracket liao..:P then somemore no need to find de ignition line.. cos cigarette power depend on ignition key wan..
well i think de voltage at there is a little lower than from de battery.. but nvm lar.. still got reading... now my battery old liao.. i think wil kaputt no long more.. so i also cant say whether de reading is accurate or not..
[snapback]831881[/snapback]​
icic, nvm la, wait for ur news when u compared to multimeter...
cause now considering to buy this volt meter or those multimeter... i think volt meter more in fancy la, but multimeter more accurate... then battery also no need to see in everyday, one week check once also ok... so that's y still considering buy which 1... hahaha... headache... -.-"...
:P
well b4 i install this meter... i got use a digital multimeter measure de voltage b4.. well since my voltage is fluctuating due to old battery so i have to measure again to compare...
well.. i install this meter bcos i lazy wanto take out de multimeter n measure.. mafan mah.. then can make my car inside look better mah.. :P n i can monitor de voltage of my car all de time... B)
[snapback]831928[/snapback]​
ya agree, take the multimeter to measure also a bit lazy when the "3 minutes hot" gone liow... haha...
but if this meter not accurate, also not so worth to spend for it la... if accurate, then is a very good buy... :D
haha, i pening in the middle of 2 road... :ph34r:
well... i think this meter should be accurate lar.. autogauge wor.. many acc. shop also selling it... taiwan made... not china..
at 1st i keep looking at de meter when driving... wah.. feel a bit dangerous.. so nice mah.. kekeke :P but later ok liao.. onli look at de meter at traffic lights.. or when car stop..
for covering the rear of the meter can use aluminium tin. im using nescafe tin for my vacuum meter, ngam2 fit, 2.5". ;)
I'd like to install a few guages to my Wira... but guess I shud wait for warranty to finish first... ;)
1) Volt meter
2) Oil pressure
3) turbo timer :P
4) boost meter ( oni when i change to GSR engine)
those r de meters i like to install :D
well.. de rear nobody sees it.. so no cover anything lar. just at de sides i use black matt sticker to cover it up.. B)
actually how the voltmeter will act during car running ar?? move a bit bit?? i like to see thing moving one ler (like vacumm) else just like putting a clock there...hehehehe..sorry ar..i know it's for monitoring, but if i put it, it's plainly for decoration heheheh :lol:
