Guys, I have installed a set of HID my self last 2 months or so but surely less than 6 months. Then starting last month the (L) side HID sometimes won't turn. I've to switch off the lights and switch it back on again so that both side lights up. Some times, I've to repeat the same sequence 2~3 times then only it will light up. I gave the seller a call since its a new set, he promise he can change for me but he told me to use this method see whether it can solve this problem or not.
He told me to change the fuse for the head lights, original 15AMP to 20AMP. Larger amp can let more current through so it can power up the ballast more easily. If this don't work he can change for me. I would like to know if I upgrade from 15AMP to 20AMP will it cause any problems to the wiring or lights sockets? will it cause too much heat to the socket that it will melt? I know i can save the hassle and all this by just telling him to change a new set for me but I would also like to know if changing to a higher AMP fuse will it cause any problem.
Thanks for the help...
