DIY GROUNDING
I have trying hard to open the distributor screw... damn hard ~~ :(
sigh.. really need to eat more already ~~ <_<
sigh.. really need to eat more already ~~ b]
distributor screw no need unscrew it fully...
jz half enough & then slot in the 'U' shape lugs into it...& screw back...
*instead of 'O' shape lugs lah*
Originally posted by khtong+Oct 27 2004, 15:59 -->
QUOTE (khtong @ Oct 27 2004, 15:59 )
--QuoteBegin-shong
@Oct 27 2004, 15:10
[/quote]
but then, once you can screw it up, then i sure you can screw it everything out already .. .. but then .. to cut into U is a good way .. or else .. the screw drop .. then susah nak cari ..
and dont forget to drink 100plus !
:lol:
will try later again`~
Originally posted by tykoh@Oct 27 2004, 18:20
if you want to make U lug... you just need to cut it loh... so easy one...
aiya...no need so susah cut the 'U' shape from 'O' shape lah...
can buy one lah...
hmmm....grounding topic again.
basically it is as easy as 123 shown in the pic..but bare in mind that somtimes it doesn't show significant effect after u ground..the effects might vary from car to car. ^_^.
for DIY grounding...go find power amp cable from jalan pasar..whole cost should be cheaper than eunos price.happy DIY.
i haven;t did my grounding yet..hahahah
weill..where to get the one piece metal thing to hold the wire?ermm.li mean from teh battery wan leh..which you connet all the ground cables togwether into one and put it in NEg (ve -) rite>
when should we go for TT and get some help from all sifus here. i wanna do mine and where can i get those material before proceed with this DIY session?
ESCA... i wanna redo my grounding man .. all my grounding cable kaput liau .. hahaha this time must get da 4guage cable liau ...
