DIY: fixing loosen player head...
calvin00cool
3,000 RPM
im using pioneer cd player wf flip down function...
the head is loosen and will always flip down when i click it or attach it back...
any solution?plz help...thanks...
[snapback]838969[/snapback]​
maybe the spring loose already... :huh:
pioneer normal problem.. will loose 1 if always detach it.. but flip down i nvr c b4 la.. i onli saw the screen will go blank if press on it... stop detach it now
i think ur prob is due to de plastic limiter thing wear out already.. so it cant hold it back tighly... or mayb got some plastic hook wear off liao..
anyway.. i've never seen how this flip down thing work lar... so i cant give much comments... if u have some pics.. it mayb helpful for ppl to help u... pic on where de part holding de panel so dat it stays there..
try to see also whether there is any dislocation of gears or joint that is used to hold up the flip?? i saw something like this when i used my friend's car last time...
[snapback]843406[/snapback]​
yes, that's right....with a pic will help a lot.... :P
