DIY - Cleaning Your Thorttle Body
martinchan
Hi There, I Had Discover How To Clean Our Thorttle Body By DIY
First Remove The screw Of The Air box
http://i22.photobucket.com/albums/b329/martin_chan/1.jpg
2 - Same Remove All The Screw
http://i22.photobucket.com/albums/b329/martin_chan/2.jpg
3 - Remove All The Joint And Socket, The Coil Of The Arrow Should Be Easly To Remore
http://i22.photobucket.com/albums/b329/martin_chan/3.jpg
4 - If The Coil Hard To Remove Then You Need To Remove This Two Nut 1st
http://i22.photobucket.com/albums/b329/martin_chan/4.jpg
5 - Same Remove The Socket
http://i22.photobucket.com/albums/b329/martin_chan/5.jpg
6 - Same Remove The Socket
http://i22.photobucket.com/albums/b329/martin_chan/6.jpg
7 - Romove This, But BECAREFUL Once Remove It will Leak Out The Coolent Water, It Maybe Hot Depand If Your Car Engine Still Hot, So, I Recommend You Do This Before You Start Your Engine In The Morning.
http://i22.photobucket.com/albums/b329/martin_chan/7.jpg
8 - Last, Remove This 3 Nut To Taken Out The Thorttle Body
http://i22.photobucket.com/albums/b329/martin_chan/8.jpg
9 - This Is How It Look Likes When You Take Out The Thorttle Body
http://i22.photobucket.com/albums/b329/martin_chan/9.jpg
10 - Dirty
http://i22.photobucket.com/albums/b329/martin_chan/10.jpg
11 - Clean It With Fuel Petrol With Clean Cloth And Gentle, Don't Scratch It
http://i22.photobucket.com/albums/b329/martin_chan/11.jpg
12 - This Is How It Look When Finish Clean It
http://i22.photobucket.com/albums/b329/martin_chan/12.jpg
So After That Just Screw Back All The Nut And Socket Then Reset The ECU And Start Your Engine To Wait It Self Learning, The RPM WIll Go High And Low , But It Is Normal During It Was Self Learning. So No Need To Worry.
Bro,could you post the picture again for the DIY throttle Body Cleaning cause it got deleted.I am interested to DIY throttle body cleaning
Bro, do you know how to reset ecu for Wira SE.because i plan to clean my throttle body this weekend.Do we have to reset the ecu after cleaning the throttle body for Wira SE?:confused:
Can reset ecu for wira? wow.. malaysian technology is really picking up..
10 - Dirty
hey bro
the photos are missing
mind checking it ? thanks a lot
wah!!!!!!! martin now super famous man...... faster open shop, i will support you all the way bro.
Bump: wah!!!!!!! martin now super famous man...... faster open shop, i will support you all the way bro.
wah! martin kor kor.... u got what for me? i now in vietnam la. only come back every 2-3weeks. so, it's better you come down la and can yum cha with the 3 uncles [me included of course]. i bet you uncle yew and uncle teng sure agree one!
but some foreman touch the bottom part of the throttle body and says that the plastic or something like that was melting and this TB is dying.
they say its useless to replace the small gears or open & clean it.
i am not sure how true was it.
