DIY Battery Revitalizer
lcchong
Battery Revitalizer (12V)
(Released on 25/09/2008)
Sulphation is a condition when the lead sulphate that is formed on the plates of a battery during its discharge changes in structure. Fairly large sulphate crystals are formed, which block the pores of the lead plates and hence reduce their active area. This causes the capacity of the battery to be reduced — it can no longer supply large currents and it can not be charged effectively in the usual way. The most effective way to break up unwanted deposits of sulphate crystals and to restore the battery plates to a reasonable condition is by charging a short and high energy pulses to the battery, since the energy required for the charging pulses is derived from the battery itself thus discharging of the battery is also part of the process.
Battery Revitalizer is a compact slow pulsing devices that trigger an intermittence load to the battery preventing sulphate crystals buildup. It is also a Battery Conditioner for a vehicle new battery thus keeping it fresh.
KIT Model: 001- BR- 0612 (Build and Tested) Improved Version
http://www.peony888.com/VS/Dsci1386s.jpg
info from http://www.peony888.com/VS/revitalizer.htm
wah interested lah..just connect this to both battery terminal and it will do?
this is ready made kit rite?just need to assemble on the board?
