Diy Autolock
JasperSSP
DIY sifus especially JL, can we DIY this device? Like when the car speeds up to maybe 20km/h, then the door auto lock.
Errr.. NO easy.
But Handbrake Autolock is easy.
Just add a swtich at the HandBrake and wire it to you Central Lock.
Aiya, the handbrake one be syiok. Like so mafan. And I don't really use the handbrake. But anyway, how to wire it to the central locking? Any instructions or schematic diagrams?
The central Locking Wires are Standard.
5 Wires to control the LOCKING mechanism.
BLUE
GREEN
WHITE
BLACK
BROWN
Blue and Green is to control the Locking Piston. It flows in + and - to make it LOCK or - and + to make it UNLOCK
White, Black and Brown are the controller switch, to give input either to LOCK or UNLOCK.
I forgot what colour is to do what already. Try this experiment
Exp #1:
- Cross BLACK and WHITE (See what happen)
Exp #2:
- Cross BLACK and Brown (See what happen)
One of it should make the central lock LOCK and the other will UNLOCK.
Happy trying...
100 Plus. Hydrate the Dehydrated.
Thanks JL, I knew you'd know. (sounds like Rick Dees) Will try during the hols. Long list waiting for me this coming holiday in April.
1. Redo Heatshield
2. CAI
3. Cable tie my brake hose
4. Autolock
5. If got the ah beng mood, maybe will try the undercariage lights.
JL, what would we do without you? :lol:
i have looked up and down inside out and still cant find the central locking...and u mention add a button? what button?
by the way..i am new... ;)
weiwei!! i wanna make a switch (like satria uk spec wan) to lock/unlock my car doors...how do i wire it up? and what stuff would i need? drivng a kelisa btw...
thankS! B)
actually the autolock feature is quite unreliable....honda accords uses this but i dunno if it detects RPM or KMH....lots of people accidently lock themself out because they let the car idle and they stand outside. :D
Okie.. To answer to Central Locking Unit.
If cannot find.. No worries.. Just pop open the Door Panel on the Driver's side. You will see the 5 wires on the Locking Piston.
You can tap the wires from there.
Note : Central Locking Unit usually very near to the Remote Alarm Module.
Originally posted by S1997@Mar 3 2004, 01:38 AM
JL...what switch is needed to make the handbrake lock thing? or how do u do it? :unsure:
thanks!
For AutoLock when lowering down Handbrakes.
You need a small switch that turns ON when it is NOT pressed and OFF when it is pressed.
You insert the switch inside your handbrake bar. It is inside the Console. (Different for different cars.)
Originally, it will have one, to detect your handbrake LAMP thing.
I was just thinking, maybe if I wire the button to the accelerator, then it will be the closest thing to the rpm detector.
haha...i stil dont get it.okay i get the button which goes on when it is not pressed then off when pressed..then i wire it to?? i am sooooooo....confused... :unsure: :unsure: :unsure:
thankS! B)
woooooooooI! u missed my question! :angry: :P :lol:
Originally posted by tks+Mar 4 2004, 12:29 AM-->
QUOTE (tks @ Mar 4 2004, 12:29 AM)
--QuoteBegin-tks
thankS! B)
woooooooooI! u missed my question! :angry: :P :lol: [/b][/quote]
Sorry... sorry.. soryy !!!!! :( :( :(
Busy..must have overlooked.
Well. to mod this. It is the same concept with the autolock.
- Find for the White, Black and Brown wire.
- Black is a Common Wire.
- Wire ONE of the Buttons to BLACK and WHITE
- Wire ONE of the Buttons to BLACK and BROWN
Now.. When you press one button, it will LOCK.
And the other, it will UNLOCK.
Try it out. I forgot which wire DOES what :) hehehe..
Sorry..
