DIY aircond piping insulation.
sentinal3_16
My aircond pipings is bare without insulation.Insulating it will surely make the aircond cooler cause wont be affected by engine heat.Hence,what product/thing i can use to insulate the piping?How to do it?
Anybody kind to share their insulation experiance?Thanks.
use the superlon...ppl use for house air-con pipe insulation. it's a really good heat insulation material.
Hei bro good luck with your project.. do u mind taking pictures while u doing the process.... please as I will wanna try it out too...
hmm.. this is a good idea.. i also got some heatproof material left..
but didnt think of my bare aircon pipings b4.. thx for this idea.
U can buy the insulation tube from any air con parts shop.
Cut the tube in half, placed it onto the bare metal tube & then tie it with cable ties.
If u want it to look nicer, next time when u service the air con bring a spare insulation tube and slide it onto the metal tube, after the air con unbolt the metal tube from the cooling coil. It will look nicer without the cable ties.
