Distributor Problem need advice to modify..
niccm0314
hi,
i have a 4g13 carburetor car inside my Lmst, i found out the distributor is having problem cause engine jerk when AC on, rightnow intend to buy a new unit,question is can i use wira 1.6 model of distributor put it inside my 4g13 carburetor engine?if next time i want to convert my carburetor system to efi,can the carburetor model of distributor to be use in efi system without need to change?
beside this the stuff to convert to efi system is it ecu with wiring,intake magnaflow with throttle body, o2 sensor and fuel pump only? the method is when modify to efi system i need to get all of these stuff n drag supply voltage to ecu n the key to on off wiring to ecu then put the wiring from ecu though firewall to injectors n o2 sensor and distributor then the engine can b start? or not as simple like this?correct me if i wrong thank u.. i need guru to teach..
u can buy new dizzy off the shelf from spare part shop je, for the efi project, get the full wiring complete with the fuse box
