Disk Brake Questions...
realplayer
hi to all sifus...i'm driving a Wira 1.3 and the disk was already scracth and "berlekuk"..i don't want to skim the disk,coz the disk "makan" on the right side.donno still can skim or not ...better to replace it..my questions is :
1) Can i replace the disk to the ventilated disk from 1.5 model?
2) Izit "plug and play"?
3) Do i need to change the brake caliper too???
All ideas and opinion are welcome....thanks all...
1.3 n 1.5 are using the same disc pads, i assume both caliper n disc size are the same. so upgrading to 1.5 brake disc is not a problem.
if the size of 1.5rotor same as 1.3rotor ........the caliper wii b fit
if the 1.5size is bigger than the 1.3 then u have to take the 1.5 caliper as well
1.3 can fit almost all kinds of proton model....1.5,1.6,1.8 even some mitsubibishi model.....got no problem at all....just plug n play....1 of my fren 1.3 wira is using 1.8 wira disk brake all 4 of them....so its in ur hand.....happy driving....:burnout::burnout:
all right man...thank you guys..:love:.now i know the best choice to do with my lil' wira...i'm still driving it n drive it slowly....affraid cannot stop sharply...:rofl:
if want increasing braking power, i advice u change twin layer brake servo..
if u want ur brakes hold on longer before it overheats, it is best to change to ventilated disc brakes...
thanks skywalker...but twin layer brake servo that u mention from what/which model??.
hi boyzone....izit 4G91 disk thicker??....thicker iz better yek???..:hmmmm:
twin layer brake servo from evo or anything equivalent will be good enough...
not sure if 4g91 disc size is bigger than 4g15 disc size or not... but both are ventilated disc..
no, not the thicker the better... as long as it is ventilated disc, it can dispose heat faster, reducing chances of brakes overheating...
