DD 4POT 330MM brake kit fit proton inspira
d&d performance
Beyond 20,000 RPM!
DD RACING 4 POT BRAKE CALIPER KIT
*SAFETY START WITH DD*
Heavy duty stainless steel pistons reduce heat
transfer.
PACKAGE CONTAIN : CALIPER 4POT x 2PCS
DISC ROTOR 330MM x 2PCS
ADAPTER x2 PCS
BRAKE PADS 1SET "550DEG"
MATERIAL : FORGED aluminum alloy
YOU ARE BIDDING ON A COMPLETE FRONT BRAKE KIT FROM
DD///.
EACH KIT CONTAINS A MATCHED SET OF CALIPERS AND
ROTORS SPECIFICALLY DESIGNED FOR EACH APPLICATION.
INSTALLING LARGER BRAKES WILL DECREASE YOUR
STOPPING DISTANCE, PROLONG THE LIFE OF THE PADS
AND ROTORS AND FILL UP THE SPACE BETWEEN THE
CALIPER/ROTOR AND BARREL OF WHEEL
D&D PERFORMANCE
-no.18&20,jalan pjs 11/7,bandar sunway,46150
petaling jaya,selangor,malaysia.
email:[email protected]
hp: 60163328136 seng
hp:+60163328136 seng
+60162111820 kenny
+60162173767 frankie
-any enquiry please call or email
---------- Post added at 05:17 PM ---------- 6 hour anti-bump limit - Previous post was at 05:13 PM ----------
+60162111820 kenny
