Dcommander Performance Chip For Commonrail Engine
jeffrey99b
Dcommander (For Commonrail Engine)
Dcommander is a complete line of Diesel Engine Management System -DEMS, that offers you an extremely reliable and user-friendly system at a very competitive price. It gives you the possibility delivery more performance for diesel engine.
Diesel Engine Management System or DEMS is designed to increase diesel commonrail engine performance by adding more horse power and torque with no engine external/internal modification.
DEMS features:
- Increase more house power and friendly use with OEM system.
- Ease to install not affect to other OEM function.
- Able to adjust.
- Embedded with Freak Drive System
- Able to Turn On and Off the embedded system with external switch.
Production Specification
Model : D-1000
- Increase 15-20% horse power and torque
- Frisk Drive System (0-60 steps)
- Fuel Map Mode (0-90 steps)
- Power switch
Model : D-3000
- Increase 20%-30% house power and torque
- Able to manage turbo boost
- Able to upgrade software
- Boost Cut Eliminator System
- Power switch
1. PERFORMANCE
Dcommander is a kind of piggy back that you can install without cutting and disturb the sensor of the engine. This means that there won't be an error of sensor signal to ECU. You can drive without check engine light when you have problem with Dcommander's box. Engine still work by ECU. You just switch off the Dcommander's if you install on/off switch. (D-1000 and D-3000)
2.POWER SWITCH
You can install on/off switch on the Dcommander. You can turn the switch off every time you want although the Dcommander still running. But you can only switch on back during engine idling and wait for 3 seconds before accelerate. (D-1000 and D-3000)
3. Freak Drive System
It make you feel smooth when you accelerate because this mode will delay injection working and you will absolutely easy to control accelerator. The engine will not twitch. (D-1000 and D-3000)
4. Boost Cut Eliminator
This mode will unlock the boost limit from standard. You can increase boost pressure more than ECU standard. (Special for D-3000 only).
Available for
1. Toyota Hilux 2.5D Manual or Auto Year 2004 onwards
Your car will be more responsive.
Work done by a professional person.
No need to change any wiring system in your car.
For daily driven cause it will not harm your engine.
*Guaranteed Result*
Interested plz PM me for further details. Can adjust or tuned to your own preferenes. Warranty 1 year.
Price RM2900 for D-3000
Price RM1900 for D-1000
