DBA4000 Series Kangaroo Paws Rotor 276mm
Taemun
DBA4000 Series Rotor 276mm-Mitsubishi 2 pots Caliper
DBA4000 Series Kangaroo Paws Rotor for Evo 2, 3,4 and Airtrek 2 pots.
Front rotor for Airtrek Turbo, Evo 4, 5, 6 RS model, suit 2 pots caliper. Just plug and play. Please refer to DBA web site for further details.
Solid vented, kangaroo paws design, 276mm diameter, 45.5mm height, 24mm thickness, 69mm centre hole diameter, 5 holes, pcd 114.3.
Used for 1+ month. Selling because upgraded to brembo.
Price reduced to RM700(nett). [New RM1500]
Interested, call or SMS 019-7253200 (Johor Bahru)
B.u.m.P......for a set of high quality performance rotor with temperature indicators.
Came with boxes & instruction manual.......rotor look a bit old due to the oil layer on it to protect from rust in storage.
Some of the info extracted from DBA website:
"The innovative Kangaroo Paw design runs cooler, is stronger, and outperforms traditional straight vane disc brake rotors. The extreme heat can cause disc rotors to warp, distort and in some cases fail. Traditionally, heat is removed as air flows through the rotor passing between straight ‘cooling vanes’. However, the straight vane design does not provide the ideal conditions for heat to be dissipated and tends to allow an unwanted ballooning effect.
Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application – without this ballooning.
The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. The pillars create greater strength, reliability, and a more efficient cooling system. Greater surface area means more rapid heat dissipation.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade."
B.U.M.P......for high performance slotted beautifully crafted rotor
