Dashboard Panel Installation Casing Kit for Perodua MYVI
ICE -In Car Entertainment
autocrazee
Dashboard Panel Installation Casing Kit specifically designed for PERODUA MYVI.
Allow you to change your stock CD player to double-din aftermarket headunit!
Plug-and-Play Easy installation, no modification, no drilling nor screwing required!
Comes together with installation bracket kit!
Connectors uses original clip-points.
You can select from our wide range of aftermarket HD DVD Players, with optional GPS functionality, to fit into your ride:
http://audiotech.12v.com.my/specsheets/head-unit-spec-sheet.html
