D15B (3 Stage VTEC) Serious Problem... Need Help
rapinsoul
Hi Hondarianz out there i need some advise from you guys.
My Problem are as below:
While i am driving my "Check Engine" light flash up and also while i am driving in E "Economy Mode" the D light flashes i will attach the pic's below and my KM/H meter dies, the picture attached is captured while i was driving. I have Circle It in RED
Need your help and also some infor where is a really good and reliable place to service Honda Cars. Please Note i am Driving The E-EK3 Recond Model 2 Door Civic.
Your Advise and comments will really help me alot, thanks
http://i92.photobucket.com/albums/l39/rapinsoul/06-02-07_1949.jpg
speed sensor kong probably. to confirm, you can go to a honda SC and they normally can read the error code from the ECU.
If speed sensor kong ur VTEC will not engage as well
just my 2 sen
Yep. The speed sensor is definitely faulty.. it happened to me twice and I had it replaced twice. It recently happened to another friend of mine. Same problem too. Had his sensor replaced and its back to normal.
