Reali ar?
Ken..you using Joystick o GT force Pro?
if using Joystick its true that it is hard..coz the acc control is not good as Steering wheel de pedal
So i swicth the traction control to 1, if using pedal one can swicth to zero
this is my setting 4drift using the joystick...can drift but powerslide sorry la bro...
Driving aid
-turn all to zero except traction control 1
LSD
initial:5
acc: 60
Decc:5
Spring rate
10kgm for front
12kgm for rear
Stabilizer
F- 4
R-6
depend
damper i adjust for rear only
bound 4
rebound 6
Camber
F- 3.0
rear- 1.5
you can change lower grip rear tire
purchase 2different compoung tires then change front with higher grip relative to rear
i didnt do this coz i try it b4..you experience it yourself..haha
n BTW...this is the setting i drift using Nomuken ER34...
Driving aid
LSD
initial:5
acc: 60
Decc:5
Spring rate
10kgm for front
12kgm for rear
Stabilizer
F- 4
R-6
depend
bound 4
rebound 6
Camber
F- 3.0
rear- 1.5
