D.i.y
Originally posted by soulfly@Mar 2 2004, 08:17 PM
potong dan buang, welding pipe baru
Yeah.. I think that's the way :)
Anyway.. Cat have 2 X flange thing on both sides. You can unbolt these... to take them out..
Then DIY weld another Stright Pipe with Flange on both ends (same length).. and bolt on.
Originally posted by JasperSSP@Mar 3 2004, 12:09 PM
Can replace with a bullet also.
your's senang ler.. my cat is rite at the bottom of the exhaust manifold... so need to change exhaust manifold. <_<
izzit true if u remove ur cat converter n replace it with a dummy cat or straight pipe, it will boost ur car performance? will it sound very loud then?
Majority of ppl throw the 'cat' away because it restrict the air flow on some cars especially turbo-charged ones.
Actually, there is another product used by ppl in the US (because their laws require 'cat' to be installed by the manufacturer).
The product is called ATP Virtual Exhaust. It is a diverter valve that by passes the exhaust system under full boost.
any URL...??? :o
Originally posted by JINEIL2EN@Nov 9 2004, 10:32
any URL...??? :o
Yes.
Here: http://www.atpturbo.com/root/releases/release091004.htm
I doubt u can find it locally... check out the vids also. Big differences. :lol:
Originally posted by acbc+Nov 9 2004, 12:48 -->
QUOTE (acbc @ Nov 9 2004, 12:48 )
--QuoteBegin-JINEIL2EN
@Nov 9 2004, 10:32
any URL...??? :o
Yes.
I doubt u can find it locally... check out the vids also. Big differences. :lol: [/b][/quote]
wah....that's great item...
jpj no time to check ur cat or not one lah...haha... just remove it to gain a bit power lah.... but i still not yet remove...heehe :P
