<< custom bracket for brake caliper upgrade >>
AvanT
Custom fabricator & CNC machining
Please give us a call if U are planning to upgrade to bigger OEM or aftermarket brake calipers to improve your braking power.
Here is a list of machining services we offer. All are designed on computer & machined on precision CNC machines:
Machining new 4 x 100 PCD mounting holes on 5 x 114.3 PCD disc rotors
Machining new 5 x 114.3 PCD mounting holes on 4 x 114.3 PCD disc rotors
Custom made center cone to hold your disc rotors
To modify your wheel knuckles to fit your brake calipers
To custom design & fabricate bracket to bolt-on your brake calipers
[email protected]
012-283-3635
Nissan 4-pot brake calipers on Nissan Sentra N16
Evo7 4-pot brake calipers on Toyota Estima
Man, I wish you were offering this sooner. I would've continued with my brake project.
Do you do custom 'hats' for the 2-piece rotors?
Subaru 4-pot brake calipers on Subaru XV
Nissan 4-pot brake calipers on Toyota MRS
Toyota 4-pot caliper on Toyota Harrier
Custom brake caliper brackets for Nissan GTR 34
Custom brake caliper brackets for Mazda CX5
BEFORE
IN-PROCESS...
AFTER
CNC machining custom slots for disc rotor
Custom designed low profile 15mm wheel adapter with hex bolts & dual PCD (114.3mm ->139.7mm)
Sorry bro Jambunk,
We do not stock brake caliper brackets because there is simply too many different car models, disc rotor & caliper combination & configuration. Every job is custom made from us.
CNC machining custom slots for VW MK6 disc rotor
Computer designed & CNC machined custom brake caliper bracket for Toyota Altis
Contact : 012-283-3635
Computer designed & CNC machined custom brake caliper bracket for Nissan Navara NP300
4-pot NISSAN caliper + 330mm disc rotor
Custom designed & CNC machined brake caliper bracket for Brembo 4-pot on Alfa Romeo
