cooling system
rayracer
halo! izzit a good cooling system will be good for engine performance?
last time my car(satria 1.3 carb) repair the radiator and head gasket(the gasket blow),and then i try to rev up,wooo!!
i feel the car going too smooth the power! i c the water temp is going down,(normally in middle)
i planning to upgrade the cooling
-radiator cap 1.3kgm (normal 0.9kgm)
-high pressure radiator hose
-radiator cooling plate (fit infront of grill above)
-radiator bubble catch tank
izzit o.k? or still wanna add something?
pls share:shades_smile:
all the items u mentioned there creates a good cooling system.
and yes,it will surely give u some hp gains coz when ur engine is in a optimum tempreture.
but i have to warn u first..if ur engine is stock and its not a heavy/not so heavy modded one..no matter how cool u make ur engine be..it wont give u a heck of a lot of hp gain.
A radiator from a 4G92 or 93 will provide much more cooling and cost one third of all the parts that you mentioned..
all the part from above izzit also fit for proton satria??
like the high pressure radiator hose i found n c magazine always only have hot car model.
if my car upgrade all performance part,but the cooling system still remain in original,also no better effect.
this is y when u mod ur engine heavily..u need a cooling system to match it.
engine mods and cooling system goes together.
