Converting Wave Files To 32 Bit
rsctan
i concerted mp3 to wave then i tried upgrade it to a 32 bit wave..when i saved it i have this file .pk and when i try to burn it with nero it says invalid file worng format...but i can play the file in my pc..why cant i burn it? any idea? or you have some other way doing the same? :( :(
I believe you are trying to burn the audio file as an Audio CD right? Well, won't work because Audio CD sampling rate it 44.1kHz and 16-bits only.
The reason why you can play the file on the PC is because the hardware (soundcard) can support 32-bit wave file (some do downsample to 16-bit).
