confuse?? don know is piston rings problem broken cause engine oil drop or not...
niccm0314
hi boss,
my 4g13 done top head overhaul n changed all the valve seal.Problem is the level of engine oil still drop a little, top head overhaul done well n no any oil mark on to my block n other parts, isn't piston rings broken cause it eat engine oil? NOTE when ramp it to 7 to 8k rpm, smoke like a bit dark white will release at the tail exhaust.. isn't this is the symptom of piston ring broken? for information my exhaust muffler already leak..:burnout:
hi,
do any shop have this test? i went to the shop b4 but the mech just agak agak only... do i need to go to the special shop to do compression test?:confused:
