cold start prob... n idling not stable
gti[GSR]
i hav dis prob... cold start its jus so hard to start da car... onli cold start, once da engine is warm enuff, no prob startin da car alr... y ar?
also, sometimes when i leave mah car idle... for 5 mins max to 10 mins, sometimes mah check light comes on... y? sometimes when i rev it a lil or move da car, check lgiht also on... SOMETIMES ONLI... can it b ecu? air flow been changed few times... still same prob...
dis is a GSR wif gti dashboard, so i dunno how complete are da wirings... also those diagnostics things plug into car to check car check light, came out nothin even tho da check light is still on... where can i diagnose da car instead of proton/ anyone has it for JAP CARS? how much n wherE????
pls help
thanks
pls help
thanks
hi there..
so what car did this engine u put in? do u have any diagnostic cable or did u transplant the whole dashboard too?
need to check ur TPS posistion, ISC reading, injector reading, o2 sensor and override ecu iding memory.
pls contact me at the number below.
will help u to solve this problem... call for free consult.
http://rpm.motorsport.tripod.com//steven/thumbnails/600x450/52770015.jpg
Originally posted by mxsteven@Mar 11 2005, 10:51
hi there..
hi steven ... any estimate of how much dis will cost.... thx
Originally posted by partyJOE+Mar 11 2005, 11:01 -->
QUOTE (partyJOE @ Mar 11 2005, 11:01 )
--QuoteBegin-mxsteven
@Mar 11 2005, 10:51
hi there..
hi steven ... any estimate of how much dis will cost.... thx [/b][/quote]
Clear error codes RM40
Clear error + tuning and ISC service + override ecu setting RM100 neg with 1 month warranty
ps: warranty only for tuning means that if u accidently took off ur battery teminal then u can come for a free error code clearing or even tuning. warranty for 30 days or 1 month. only for ZTH member only.
bro...
mah engine is GSR, mah dashboard is GTI... how leh? i did went 2 places to diagnose da car, but came out nothing... i think due to da cable not able to read mah car situation... their machine cant read... dats y i need to make sure urs able to read da check light?
how urgent? now da workshop says its mah ECU rosak liao... dunno dem lar, first say wirign for air flow now says ECU... dey say dey resetted da ECU alr... n still like dat, da prob is cold start prob when i first start da car durin da morning... den after dat no more, den, durin day time noon, once car hot, start da car, after 10 mins da check light comes on... sigh
help lor
how how???
Originally posted by gti[GSR]@Mar 11 2005, 12:19
thanks bro... jus called u... ur mah saviour... will get back to u asap
thanks thanks thanks
wahhhhh this posting damn kaw one..... after an hour posting 5 car came and then now onother 5 car..... after this done i will come to the workshop to get urs settle... i will bring along 2 japanese guy to provide me help in case hahahaha
gti[GSR] problem solved... coolant CTS sensor faulty and inigtion sensor short. Remark ecu and re-initialiast the ecu ok. So far so good but need to recheck again for safety reason.
and one more ZTH member came this afternoon with his satria mivec, really sorry coz ur ecu not mivec thats why mivec valve not working anyhow the wireman did ur car is great but wrong ecu so now i reconfigure ur car with vafc. hope it works well........ coz this is also first time modified like that coz no choice.... i hope u dont get angry with this issue, technical things never lie or u can ask ZTH member "can mivec be run on non mivec ecu (1.6 ecu)"
Originally posted by gti[GSR]@Mar 12 2005, 11:26
steven, i'm still havin difficulty startin da car earli in da morning.... once warmed up its ok... how ar?
just now i went to CW auto... Keong said he changed the CTS sensor and rewire ur aircon due to ur aircond wiring problem... u mean now still the same?
i think if possiblle pls bring ur car over my shop i'll help u to do.
yupz he did changed da sensor, is GSR same wif GTI sensor? one is NA one is turbo wo???
yea da aircond wire had been corrected...
yea jus morning start now... damn hard idling... laggy feel after step on accelerator 2 lar...
how how?
how how?
does the check light still come on?
i think ur cold start temp not working..
maybe after u get the car done then u come to my place?
wat ya think?
hmm yea i willz... ho wmuch to replace cold start temp? nah da check light not on alr...
i will cal u once mah car out... thanks
ok i will wait for ur car ok!
bring over lah once ur car ready!!
