Clutch getting stiff
hey guys,
I was wondering, are any of you 1st GEN neo owners experiencing any stiffness when
stepping on the clutch? (during idle and driving)
I went to a foreman and he said that this was a common complaint among neo owners.
If this is true, is there any way to fix this issues without resolving to buy a new clutch pump?
thanks, and cheers!
DONE! THANKS! clutch got smoother abit...
how often does the clutch need to be bleed-ed?
how often..
i dont think it is specified in the manual book.
when it feels wrong then we bleed lah :p
or, every time you bleed your brake fluid, bleed the clutch as well. as the clutch and brake system share the same reservoir.
---------- Post added at 12:45 PM ---------- 6 hour anti-bump limit - Previous post was at 12:44 PM ----------
clutch & brake share the same reservoir & fluid right?
correct, satria neo model, brake & clutch sharing the same reservoir.
