Clutch, Brake & Accelerator
mivec98
Hi there.
I might sound a dump dump but here goes.
Does Wira 1.5 model year 1994 (cab) uses cable for clutch, brake and accelerator??
I know clutch uses cable. A few months back my clutch cable broke when i was travelling around the neighbourhood. Called the mech. He came over and change it there and then.
Now my worry is, if the clutch cable can break, and if the brake and accelerator uses cable than i should be worrying, rite?? After all, it is a 11 year old car.
Em, how much does it cost to change them and how long does it take to change them???
Thanks guys in advance for your input.
normally...clutch will broken only....accelelator very rare happen.....brake pump got to check..will leaking n cause u no break...flush clutch n brake oil if u nvr flush it.....
dear friend
your brakes don't run by cables. it pushes the fork which in turn depresses the diaphragm and stuff... so don't worry bout cables breakin.
