CLOSED
CLOSED
apexi3016 :- kayaba rs is short stroke type..performax normal stroke(like OEM)...in term of performance kayaba rs a little bit better than performax(but it depends on 'ur sport spring)...both are local made
deftons :- u a using speedkit huh?..hehehe..i've used it before ;) red in colour right?onthat time i used speedkit sport spring with r-tech...but i never try it with performax because i already upgrade to eibach...i think u can get comfort also by using performax...no comment for monroe...
Yo Arer!!!
Need your opinion on APM Performax + Eibach Pro-Kit. Also how much for Waja 1.r(M) - full set fr and rear. Thanks.
RAD
Hello there,
So do u have stock for honda civic EG9 now? i'm also interested...wat is the price? i assume the price u quote is without installation right?
Do u carry the APM adjustable abs too?
RAD :- mm..for me the combination of eibach & performax is good enough...coz i'm using this combination on my car...for the price i'll check for u later k...
freak :- yup..da price is without installation...i need to check 1st whether is it available for eg9 or not...i'll inform u later
if u take whole set (front+rear) i can u give a little bit discount... ;)
just for that case only
arer,
hi pal, ohh u used b4 har speedkit..yea it's red in color ;) hmmmm...hows the feel for speedkit together with the r-tech..?comfort?bumpy?i planning to change my abs adi..wonder if r-tech will lower the ride or not..or juz the same as OEM abs..do enlighten me dude...thanx B)
i can't tell much about speedkit... but it feel with r-tech combination better than using OEM abs.. the height aspect had no different on both type abs.. ;)
hmmm...so u mean that if with the r-tech..the height will still be same with OEM right..?how much for a full set..
this performax can be categorized as gas type absorber.. but r-tech is half gas/oil type.. right now it is hard to find new set of r-tech
i wanted to buy...but the installation is dam freakin expensive...last time i brought my friend change the absorber in the tire shop...they charge rm20 for each absorber placing! not including alignment!
